-   -   cold water pressure low in new faucet (http://www.diychatroom.com/f7/cold-water-pressure-low-new-faucet-98579/)
tndale 03-16-2011 11:15 AM
Plumber installed new faucet, the cold water worked fine for 4 days then pressure dropped to less than 50% Kholer sent new valve, no difference. They had us switch the cold line to the hot to see if it would work--it did. Tried hot water tubing on cold but same result low pressure. Kholer says not their problem. Ideas?
Mike Swearingen 03-16-2011 03:15 PM
Sounds like loose floating debris in the cold side of the faucet.
Turn the water off, dismantle the faucet and cover it with a towel.
Turn the water back on very briefly to flush the debris out of the faucet body. That should clear it. Been there. Done that.
Sometimes, you have to take a small Phillips head screwdriver or an icepick to break up the little hungup piece of debris so that it will flush out.
Good Luck!
Mike
