Cold Water Pressure Low - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2008, 08:50 AM   #1
Cold water pressure low
Hi
I have a newly fitted shower system in a loft conversion with stand alone hot water and cold water tanks with a Monsoon Negative 3.0 bar Twin pump and a Triton Thames Bar Mixer with Diverter shower. I like to have cold showers but when I go to just cold the pressure is very low. A hot shower is fantastic. I have been told that this is because it is only using 1.5 bars. It seems less than half the pressure to me. Can anyone give advice or help on making the shower more powerful on just cold
Barry
Showerpower is offline   Reply With Quote
Old 01-19-2008, 01:45 PM   #2
Rewards Points: 150
You could 'try' taking the pressure reducer,,,flow regulator out!! for all or mostly all cold it may help,,,are you the ONLY one to use this shower tho?? Others results may vary the outcome!!
justdon is offline   Reply With Quote
Old 01-20-2008, 08:25 AM   #3
Hi Justdon. Its just me and the missus using the shower. I will try this. Thanks for the help
Barry
Little to no water pressure egglesh Plumbing 7 02-19-2007 07:42 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
hot water effecting cold water pressure hp1964 Plumbing 1 06-23-2005 05:51 PM
