Cold Water Pressure And Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2011, 08:43 AM   #1
Cold Water Pressure and Drain
So I actually have 2 questions. I am on well water, have a new pressure tank, and a tankless hot water heater. My hot water pressure is great but my cold water pressure is horrible. I do have a water treatment system and the utility sink next to the treatment system has good pressure for both hot and cold. Can anyone give me some guidance on what it could be or what I should check?
Also, when I fill the tub and then drain it, water often comes up my sink that is several feet away. I did not do the plumbing in that bathroom and it is under a cement floor so I am not certain of what is actually happening there.
Thanks in advance!
jakedp is offline   Reply With Quote
Old 03-24-2011, 12:09 PM   #2
Rewards Points: 1,512
The common drain pipe beyond both the tub and the sink is clogged.
The cold pipe beyond the utility sink may have arteriosclerosis. How old is the house?
Which comes first from the pump? The treatment system or the utility sink?
Old 03-24-2011, 12:59 PM   #3
Allan,
Thanks for the response. The house is OLD, built in 1936. New plumbing was put in throughout the house over the last 8-15 years as things were remodeled and updated. Your response is interesting as I sometimes have my washer not fully drain. I never thought of that be related but maybe it is? The actually plumbing from the utility to the sinks are probably 8 years old. It goes home-treatment system-utility sink. Arteriosclerosis? Sounds serious? Maybe I need a surgeon! LOL!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 06:48 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
