Cold Water Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2013, 07:16 PM   #1
Rewards Points: 326
Cold Water Pipes
Hi All
Today, i noticed that my cold water pipes had a lot of water on it. Check out the pictures, Water did accumulate enough that it dropped to the basement floor.
help
PTMD
Amitabh is offline   Reply With Quote
Old 06-23-2013, 07:32 PM   #2
Rewards Points: 22
It's condensation from the cold pipe coming in contact with moist warm air. Any idea what the temperature and humidity levels are?
Dan
djlandkpl is offline   Reply With Quote
Old 06-23-2013, 07:34 PM   #3
Rewards Points: 326
probably high and high, as my AC is not working properly and its extremely hot!
Old 06-23-2013, 08:02 PM   #4
Rewards Points: 252
You can try an oscillating fan, exhaust fan, or dehumidifier until your ac is up and running. Something that will keep the air moving for the time being would help.
jmon is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 04:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
hot n cold water pipes in bath vanity handekaps Plumbing 4 01-10-2010 09:49 PM
