Cold Water Pipe Condensation - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2012, 10:37 PM   #1
GBunny
Rewards Points: 71
All of a sudden, the cold water pipe in the basement has condensation all along the exposed parts. I noticed the floor was wet underneath in one spot so I'm wondering if there's a pinhole leak. How do these develop? Is it something I can fix myself and if so, how?
*** I just found the answer after doing some google reseearch - the new toilet in the basement was running. Amazing what you can find out when you look ***
GBunny is offline   Reply With Quote
Old 03-18-2012, 10:56 PM   #2
Missouri Bound's Avatar
More than likely it's just humidity. Wipe them dry and insulate. You would see a pinhole leak, and it wouldn't show along all the exposed areas.
Do you want it your way or the right way?
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 02:53 PM
Condensation line flowing lots of water (pics inside) Volleyballer[G8 HVAC 12 07-26-2010 01:46 PM
Which Gas Hot Water Heater walds11 Plumbing 66 01-16-2010 08:38 AM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 01:16 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
