Cold Water Hose - Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2009, 06:41 AM   #1
Cold water hose - washing machine
I want to move my washing machine from the kitchen into the bathroom where there is suitable plumbing under the sink. I tried to fit the cold water pipe to the tap but the plastic screw connector at the end is too large - the gap between the tap and the pipe behind it is around 1cm only, strangely enough. I am told that the last tenant had a washing machine in there so I know there is a solution. I've searched but can't find a cold water pipe with anything other than the standard size screw connectors. Any ideas?
http://www.4ourhouse.co.uk/cgi-bin/pic.pl?pid=71666
cmcgowan is offline   Reply With Quote
Old 01-08-2009, 10:13 AM   #2
Remodeling Contractor
Box stores will have the adapter you need
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 06:20 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
Washing machine - hot water supply only? Sosh Plumbing 4 07-11-2007 03:36 PM
