Cold Supply Hums Loudly, Only When Running Outside Spigot. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2013, 01:51 AM   #1
Cold supply hums loudly, only when running outside spigot.
Hello all, I have a problem with my cold supply line humming when I run my spigot that goes to my back yard. The spigot is the highest point in the cold supply other than where it branches off and heads up stairs to fixtures. The humming starts almost right when I turn the spigot on, and stops as soon as I turn the spigot off. Also, I never hear the humming when I run any other fixture in the house, in front of or behind the spigot. I re-piped my house last winter in an effort to run all my supply lines along the side of my basement, as I am finishing the basement. I also had to replace that spigot when I re piped, as the old one had froze and cracked (idiots that owned the house before me left the hose on ans the spigot open all winter), Im wondering what could be causing this?
Thanks!
-Brent
branewrock8 is offline   Reply With Quote
Old 01-26-2013, 01:57 AM   #2
Rewards Points: 13,270
Loose washer where it seals inside the sillcock, high water pressure, pipe not clamped close enough.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (01-26-2013), oh'mike (01-26-2013), plummen (01-26-2013)
Old 01-26-2013, 06:35 AM   #3
DIY staff
Rewards Points: 7,174
Yep---usually a loose washer --pull out the stem and inspect/tighten/replace the washer---
Old 01-26-2013, 07:34 AM   #4
Rewards Points: 582
I third that motion tighten washer and try it again..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 01-28-2013, 12:06 PM   #5
So are you guys saying to unscrew the spigot from the copper inside the house, or are you saying to take the handle off and pull the guts out of the spigot? Thanks! Would have wrote back sooner, but it kept telling me my password was wrong! Got it now! THANKS!
brandnewrock8 is offline   Reply With Quote
Old 01-28-2013, 12:12 PM   #6
Comes apart on the outside.
Old 01-28-2013, 12:32 PM   #7
joed's Avatar
Rewards Points: 11,990
Turn off the water supply and remove the guts from the outside. There will be a washer at the end of the long stem.
Old 01-28-2013, 02:51 PM   #8
Right on thanks joe!
Old 01-28-2013, 06:15 PM   #9
Roofmaster
Rewards Points: 2,172
Just replace it with a ball valve. Why mess with it? Life is too short to waste time on a valve.
Tags
hum , humming , running , spigot , water
Running wire through a cold air return? beezlebub03 Electrical 37 02-28-2010 11:57 AM
Is it normal to change the upper line at the meter when running new supply line? twilightcall Plumbing 3 08-08-2008 12:10 PM
Running new Main supply from Meter PEX or PVC? twilightcall Plumbing 7 08-03-2008 08:00 AM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
Running Supply to Attic cibula11 HVAC 2 02-06-2007 06:08 PM
