Coil Mixing Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2010, 03:37 PM   #1
Coil mixing valve
I have a four level home wsith three zone valves. I have an oil fired hotwater baseboard heater which supplies the heat in the house and also I have a seperate Oil fired hot water heater to supply hot water for the house. My furnace is equipped with a coil inisde the the furnace to supply hotwater for the house. But was never CONNECTED.. I wanted to link the furnace coil to heat the hot water during winter months as the furnace is runing all the time any way, and when ever I need the hotwater for shower and wash erc. the seperate furnace comes on. I was talking to a plumber, he suggested to me that he need to install a coil mixing valve which is $59.00 and the labour $200.00. I have done a lot of household plumbing myself like installing showers, kitchen and bathroom faucets, cleaning furnaces etc. I have done the complete plumbing at my cottage including installing electric hotwater tank and other plumbings with pex pipes. Do you think, I can handle installing this coil mixing valve myself?
kmydean is offline   Reply With Quote
Old 12-28-2010, 05:50 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... Sure,... Why not,..??
You'll also want to add a water volume reducer at the entrance to that coil...
When I switched from electric dhw, to my boiler domestic coil, I just plumbed it straight through 3/4" copper....
The Hot shower lasted a few Seconds...
I added a volume reducer, 'n cut it down to 2.3gpm I think, 'n now the hot showers can last Forever...
The tempering valve you're talkin' about is only a few more solder connections...
I plumbed 1 in because I was told it's Necessary,...
Luckily, I added plenty of extra valving when I did it,...
I've had it by-passed almost from the start,...
I can Temper my own water, at the Faucet.... Don't need that valve cooling it off For me....
But that's just Me, I guess....
This is all without the storage tank,...
Bondo is online now   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Moving/Installing new mixing valve... issues with framing rodney23 Plumbing 6 12-12-2010 04:32 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
