Code ?: Gas Water Heater Indoors - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2012, 02:46 PM   #1
code ?: gas water heater indoors
A plumber told a person I know that the code now prohibits installing gas water heaters indoors. Can this be true?
pyper is offline   Reply With Quote
Old 01-03-2012, 02:48 PM   #2
Rewards Points: 14,014
Not true.
Old 01-03-2012, 02:53 PM   #3
Rewards Points: 582
where are they to go???
Old 01-03-2012, 02:58 PM   #4
Rewards Points: 338
maybe he meant in a living space, i.e. it can only be installed in a garage or in a dedicate attic space.
cause otherwise, that don't make no sense. i guess throw it on the roof??
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
ben's plumbing (01-03-2012)
Old 01-03-2012, 10:26 PM   #5
They can go anywhere, except in a space used for sleeping.
I think something got lost in the re-telling.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (01-04-2012)
Old 01-03-2012, 10:31 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Doesn't it still have to acquire it's combustible air from outside of the building?
Journeyman Plumber
Old 01-03-2012, 11:04 PM   #7
Yes it does. It's easiest on an outside wall, but not all clients are that accommodating.
Old 01-04-2012, 10:46 AM   #8
This one is in a basement.
So an outside air kit is necessary?
Old 01-04-2012, 05:05 PM   #9
Two choises, fill the house with carbion monoxide and die or vent it outside.It's also going to need a stand for it to sit on to get it up off the floor.
Not really a DIY job to do this.
Old 01-04-2012, 09:57 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Depends on how much combustion air you have in your basement to support it and furnace,depending on install location of course
plummen is offline   Reply With Quote
Old 01-04-2012, 09:59 PM   #11
plummen's Avatar
Uh i think theyre talking about combustion air,not flue gasses.
Not a do it yourself job to install a water heater??????
Old 01-04-2012, 10:33 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 818
This thread is hilarious, Nobody is on the same page
Old 01-04-2012, 10:57 PM   #13
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
G2406.2 (303.3) Prohibited locations. Appliances shall not be located in sleeping rooms, bathrooms, toilet rooms, storage closets or surgical rooms, or in a space that opens only into such rooms or spaces, except where the installation complies with one of the following:
1. The appliance is a direct-vent appliance installed in accordance with the conditions of the listing and the manufacturer’s instructions. 2. Vented room heaters, wall furnaces, vented decorative appliances, vented gas fireplaces, vented gas fireplace heaters and decorative appliances for installation in vented solid fuel-burning fireplaces are installed in rooms that meet the required volume criteria of Section G2407.5. 3. A single wall-mounted unvented room heater is installed in a bathroom and such unvented room heater is equipped as specified in Section G2445.6 and has an input rating not greater than 6,000 Btu/h (1.76 kW). The bathroom shall meet the required volume criteria of Section G2407.5. 4. A single wall-mounted unvented room heater is installed in a bedroom and such unvented room heater is equipped as specified in Section G2445.6 and has an input rating not greater than 10,000 Btu/h (2.93 kW). The bedroom shall meet the required volume criteria of Section G2407.5. 5. The appliance is installed in a room or space that opens only into a bedroom or bathroom, and such room or space is used for no other purpose and is provided with a solid weather-stripped door equipped with an approved self-closing device. All combustion air shall be taken directly from the outdoors in accordance with Section G2407.6.
From the IRC 2009.
Andy.
AndyGump is offline   Reply With Quote
Old 01-05-2012, 09:03 AM   #14
We were talking about a vent for intake, not exhaust.
The exhaust is vented through the roof. There's already a gas water heater there, we're talking about replacing it when it wears out.
Old 01-05-2012, 09:08 AM   #15
Plumber
Rewards Points: 818
You can still use gas wh indoors. There has been no major code changes. Think about it. How loud do you think the manufacturers would cry if they can no longer produce gas water heaters? The lobbyists would go nuts
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
