Old 12-09-2011, 12:10 AM   #1
code for draining water softener in sump pit
is there any national pluming code that prohibits drainig the water softener into the sum pit. (let us assume there is no "local" code)
as pointed out in the fourm, there could be an issue with the pump corrosion but that does not apply in my case.
btw, the intsructions (for the softener) imply it could be drained into a sump but they also have disclaimer
drgkjd is offline   Reply With Quote
Old 12-09-2011, 07:34 AM   #2
If the sump goes outside, I would not want that salty water on my yard/trees/etc.
Old 12-10-2011, 12:39 AM   #3
that does not answer the question-- the question is is there a code against it?
the water will not go on grass or shrubs
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Draining water softener through sump pump nancygecs Plumbing 3 11-29-2011 07:31 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
