Old 03-26-2010, 07:08 PM   #1
Question
Cning caulking
I've never had this problem before but after getting a new toilet installed, the caulking this plumber used has become stained with urine. I have used bleach, all sorts of bathroom cleaners, scouring powder, the scrubbing sponges like Mr. Clean's, etc. but NOTHING REMOVES the stain! I know it is "clean" after using so many products but it is extremely unsightly! Is there an effective cleanser or another caulking I can use that will be less likely to stain? My husband takes a medication that is coated with a yellow covering and it may be that BUT didn't have the problem with the old commode! Thank you!
meka is offline   Reply With Quote
Old 04-01-2010, 04:28 PM   #2
Cning caulking
I would recommend removing the old caulk, and applying a new bead of phenoseal for bathrooms. Let it cure, and then you can pee on it again with no problem, lol, joke.
slickgt1 is offline   Reply With Quote
caulking shower question amandalc04 General Discussion 9 01-31-2010 01:05 AM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 09:33 AM
Need help with caulking problem and fuzzy wood! Beth777 Painting 4 07-04-2008 04:06 AM
