Old 01-06-2013, 08:42 AM   #1
Jackof-all Masterof- none
Closing in my sump pit
Hello All. I am currently finishing my basement and I am about to construct a wall frame for a room near my sump pit. Does anyone have any suggestions regarding the distance I should stay away from the pit itself? Any experiences or suggestions would be helpful. Thanks all.
Pigonahog is offline   Reply With Quote
Old 01-06-2013, 08:51 AM   #2
Super Moderator
Make that closet 2 feet by 2 feet minimum,if possible---when changing pumps the elbow room helps---If you might need a battery back up---make sure there is room for the battery without having it sit on the lid---
Pigonahog (01-06-2013)
Old 01-06-2013, 03:19 PM   #3
Thanks for the reply oh'mike. I'll definitely do the 2' on one side and I'll have a few feet on the other side, as it will carry behind the room I am framing.
Also for future posts I will remember to post that I am in Colorado. Thanks for the tip.
The Following User Says Thank You to Pigonahog For This Useful Post:
oh'mike (01-06-2013)
Old 01-06-2013, 05:43 PM   #4
Super Moderator
Welcome to DIY----Mike----
Old 01-06-2013, 06:37 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Even better if you can make that space 3x3 if possible, so that you can get at least a 28" door in there, vs. a 18" door to access.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 02:17 PM
sump pit/pump questions aliasoink Building & Construction 8 03-03-2010 12:41 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 10:48 PM
