Closet Flange Wax Ring Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2006, 11:17 AM   #1
closet flange wax ring problem
Finishing my basement...I have a 3" sewer drain pipe and I am using a closet flange with a female end into the drain pipe as it is in concrete. I have tiled the floor around the pipe. I am using a wax ring without a poly coupling. After installing the flange and setting the toilet, the bottom face of the horn on the toilet is touching the top of the face of the flange opening. The flange seems to be too high, anyone know how much space should be between the horn face and the flange opening? Also the flange opening is 2 1/2" ID, I noticed all wax rings with the coupling built in them are 2 3/4"? Is a wax ring with copling available for a 2 1/2" opening?
Sean
elkmo is offline   Reply With Quote
Old 01-14-2006, 12:34 PM   #2
There are a bunch of threads on this subject and a bunch plumbers on this site http://www.terrylove.com/forums/index.php? H.S.
K2eoj is offline   Reply With Quote
Old 01-14-2006, 02:30 PM   #3
Bingo...thanks
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
Problem Installing Toto Aquia on Closet Flange on Floor herbolaryo Plumbing 5 07-20-2007 08:32 AM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 06:58 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
