Closet Flange Uneven - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2010, 09:35 AM   #1
closet flange uneven
Hi, how critical is it that my toilet flange is level? I.e. flat.
It seems a part of the sub-floor is pushing up one side of it higher than the other. I need to put some extenders on it anyways, but I'm wondering if the issue of it being uneven is going to be problematic?
HHac8014 is offline   Reply With Quote
Old 06-21-2010, 09:55 AM   #2
There are a couple problems here. The flange should be secured to the floor, as should any extender you install. The toilet bolts could break the flange by an uneven pressure. I would suggest you investigate the reason the flange is not sitting level and try to fix it. The wax seal will make up for a small amount of unevenness, but don't expect it to seal as well.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
