Old 08-17-2009, 12:53 PM   #1
closet flange ....over the drain pipe or inside the drain pipe
should the closet flange go inside the drain pipe or should the drain pipe go inside the closet flange? or does it not matter? this is PVC and there is time for change as nothing is installed yet...thank you
moegumble is offline   Reply With Quote
Old 08-17-2009, 11:35 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Personally, I like it to go inside the drain, but it really doesnt matter. A 4X3 flange will go OVER 3" and INSIDE 4" pipe. Take your pick.
JDC is offline   Reply With Quote
Old 08-18-2009, 08:09 AM   #3
RippySkippy's Avatar
Yup..it depends on the flange and either will work. The horn will not fill any flange opening, so the waste will never be impeded by either set up.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Is this closet flange ok to use? J187 Plumbing 1 07-07-2009 07:48 PM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 10:33 PM
What to do with Closet flange jenoble99 Plumbing 1 01-05-2009 02:56 AM
Joining ABS p-trap under shower to C.I. drain pipe warriorfox Plumbing 4 01-01-2009 02:29 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
