Is This Closet Flange Ok To Use? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2009, 06:43 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Is this closet flange ok to use?
No glue, just push it in??
Any reason not to use this? Its a new installation and its currently roughed just to the closet bend. I need to add a 4" pipe straight up through the floor and then a closet flange... I don't want to use this if it's not ideal, but it seams much easier and seams like it would be fail proof in lining up.
Also, the floor is finished so I'll have to drill into the tile. Should I use all the holes on the flange, or just say, 4 of them?
J187 is offline   Reply With Quote
Old 07-07-2009, 06:48 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I wouldn't use it. If it is new construction get a flange that you glue on.
For existing flanges that hard to get to Home depot has a flange that inserts into the pipe and has bolts you tighten to expand the rubber seal. I have used them a couple of times..there OK
The problem I see with this flange is how the connection is ridgid and won't leak or fail.
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 08:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
Closet flange unsupported Richo Plumbing 6 01-02-2008 02:44 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 02:30 PM
