Closet Flange Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2012, 07:13 PM   #1
Closet Flange Help
Hello,
In removing an old toilet the lip of my closet flange broke off at floor level. All that remains is the flange portion seemingly glued inside the 4" plastic drain pipe. The flange was not bolted down to concrete.
Can I either use a inside fitting compression type replacement flange or can I just bolt the toilet directly to concrete?
Thanks in advance.
jimhar66 is offline   Reply With Quote
Old 09-30-2012, 07:23 PM   #2
Rewards Points: 13,300
Have you not posted this exact same question with even the same picture on this and other web sites and recieved the ansewers to your question?
ben's plumbing (09-30-2012)
closet flange extension BlueBSH Plumbing 2 09-27-2012 10:58 AM
Closet flange too high dank Plumbing 8 04-14-2010 02:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 09:22 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
