Closet Flange For Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2011, 06:21 PM   #16
Rewards Points: 582
Originally Posted by tomknox View Post
I plan on taking the black pipe out all the way to the y adapter, i'm also goona replace some of the 1 1/2 drain that runs back to my sink. As for the pex line i'm not concerned about the color of pex but i do see that he tied in with white pex to my hot line.
Javiles: With all that wire there, i'm not sure if he had an option on it not being beside electical. Should it be moved?? Loose unsecure pipe where???
you are doing the right thing by just replacing all of it including the 1 1/2 galvanized...
Old 12-30-2011, 11:44 PM   #17
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
More pic's, here...the old 4'' steel pipe is very short and the plumber tapped in with ferco's when doing the drain for the washer. I got more pics coming...
He should have used a cast iron wye where he cut that line in
plummen is offline   Reply With Quote
Old 01-18-2012, 09:23 PM   #18
I got a closet flange that has the metal ring that i want to install, i have dry fit it and one side is flush with the floor but the other side is about 1/16 or so off the floor. I can easily push the ring to the floor though.
1) Will just screwing it down be fine or should i put a small shim under the right/low side or what?
Thanks!!
tomknox is offline   Reply With Quote
Old 01-19-2012, 03:43 PM   #19
To The Top
Old 01-20-2012, 12:31 AM   #20
bump bump
Old 01-20-2012, 06:08 AM   #21
plummen's Avatar
Thanks!!
Does pushing the high side to the floor distort the flange or move the pipe?
Old 01-20-2012, 09:56 AM   #22
Rewards Points: 150
Out of curiosity, why?
psilva8 is offline   Reply With Quote
Old 01-20-2012, 11:02 AM   #23
plummen's Avatar
Differant expansion/contraction rates of differant materials,would definately get tagged around here.
If you put a cast iron why in there and run pvc past that point it would pass that part around here anyway
Old 01-20-2012, 01:28 PM   #24
plummen: It mostly bends the metal down but the pipe does move a tiny bit.
Old 01-20-2012, 01:35 PM   #25
Rewards Points: 150
Shim it level with something non-corroding and anchor to the subfloor
Old 01-21-2012, 10:55 AM   #26
psilva8: Actually i should have stated that it's level when i push the flange down flush with the floor. So a shim will basically have it too high, not sure what to do...i guess my pipe coming up isn't perfect??
I'm hoping that when i screw it to the floor, and the weight of the toilet on top that it should be fine. I would like some opinion's though, beceause it's not going in until i feel secure about it!!
T
Old 01-21-2012, 11:05 AM   #27
Plumber
TheEplumber's Avatar
Rewards Points: 556
T
If the gap is too much, the metal ring might pop off the flange while anchoring. But if its truly 1/16" gap I wouldn't worry.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
plummen (01-21-2012), tomknox (01-21-2012)
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Cast Iron Pipe ehv8trix Plumbing 4 11-25-2009 06:49 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 02:30 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
