Closet Flange For Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2011, 12:30 PM   #1
closet flange for cast iron pipe
I know this has been covered before but here's what i have. It seem's to be a 4'' pipe and it is very rough around the edge's. Also, another thing that kinda concern's me is the rust in the pipe. I have a crawl space but it's not very accessible because of the return for my heat/ac. I was looking into some flanges but wasn't sure if they would work with rust being in the pipe. Here's my question's:
1) Will the pvc twist n set or the cast iron type with the bolt's work in my situation and which is better?
2) Should i cut those edges so that they are flush with the flange i assume?
tomknox is offline   Reply With Quote
Old 12-23-2011, 02:51 PM   #2
bump...
Old 12-23-2011, 02:57 PM   #3
Rewards Points: 13,988
Will it work, or is it the best way to do it? The best way would be to get rid of all of that old cast and replace it with PVC. It's going to leak at some point.
Once you cut away the old lead with an ossilatiing tool a slip in flange will work but lub it first with vasalene.
Bud Cline (12-23-2011)
Old 12-23-2011, 02:58 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The time to address this issue would have been before the tile was installed so that maybe it could have been worked on from above for the most part.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
ben's plumbing (12-23-2011)
Old 12-23-2011, 07:08 PM   #5
Rewards Points: 582
have to agree with bud on this one...should have been addressed before tile..but it is what it is..clean off old lead install pvc slip flange with rubber gasket tighten screws for flange and anchor to floor as added support..
Old 12-25-2011, 12:08 AM   #6
I agree 100% with you guys, i honestly don't remember it looking that rusty before but my camera flash sure shows otherwise! I really couldn't afford a plumber at the time. Now, i'm thinking i can switch it out with pvc from under the house if i have to.
1) How much of that 4 inch drain need's to go? I have no clue as to whether it runs to the road or what...guess i gotta investigate that.
Thank's guy's, any help is greatly appreciated! Merry Christmas!!
Old 12-25-2011, 07:01 AM   #7
To bad the floor was not rotted out to. That way you could get to it by droping down through the floor.
Any and all of the old steel would be best if removed, including any steel supply lines.
PVC is cheap and easy to glue, but it would be best if you rented a tool made just for cutting it. If it indeed does run through the foundation wall it can be cut about 6" from the wall and reconnected with a cast to PVC hubless connector. Just tighten the hose clamps and it's done.
Old 12-29-2011, 09:29 PM   #8
More pic's, here...the old 4'' steel pipe is very short and the plumber tapped in with ferco's when doing the drain for the washer. I got more pics coming...
Old 12-29-2011, 10:05 PM   #9
Here's where the other drain leads...
Old 12-29-2011, 10:07 PM   #10
one more...
Old 12-29-2011, 10:17 PM   #11
Off topic kinda...we paid a plumber to put in the drain for the washer and he connected the the main drain i guess... Tell me please if he hooked up hot water cause i'm only seeing a blue PEX line..
1) Is that worth 400.00 dollars of plumbing work in NC??
Old 12-29-2011, 10:19 PM   #12
he looked under the house and he told me 300 actually...
Old 12-29-2011, 11:09 PM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 996
Wow Code inspectors dream. Water drain and electrical all sandwiched together loose unsecure pipe, looks like an R/R job... get another plumber.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-29-2011, 11:13 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 802
If you haven't fixed the toilet yet, I'd replace the pipe back to the PVC fitting. I'd also think about that galvanized branch too while you're down there. It will rust out on bottom someday.
I can't tell much on the PEX Colors don't mean a whole lot when all you have on your truck is blue. Blue, red, white, it's all the same.
Old 12-30-2011, 12:18 PM   #15
I plan on taking the black pipe out all the way to the y adapter, i'm also goona replace some of the 1 1/2 drain that runs back to my sink. As for the pex line i'm not concerned about the color of pex but i do see that he tied in with white pex to my hot line.
Javiles: With all that wire there, i'm not sure if he had an option on it not being beside electical. Should it be moved?? Loose unsecure pipe where???
The Following User Says Thank You to tomknox For This Useful Post:
ben's plumbing (12-30-2011)
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Cast Iron Pipe ehv8trix Plumbing 4 11-25-2009 06:49 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 02:30 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
