Closed System ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2008, 08:42 AM   #1
Closed system ?
First post here. My name is Phill from Central Mass.
For the purpose of installing an expansion tank for an electric water heater, is a well system considered "closed"
Well pump fills the holding tank (diaphram type), runs through whole house sediment filter, and then to house.
Heater will be six - ten feet from holding tank. It is a 40 gallon heater.
Old heater did not have one.
thanks.
Phill
Phill is offline   Reply With Quote
Old 09-07-2008, 12:54 PM   #2
If expansion tanks are in your local code, you will need to install one since you are repalcing an old heater. I have enclosed a link (just click on the link) that explains what they do. Good luck.
http://www.fastwaterheater.com/faq.asp#3
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-07-2008, 01:22 PM   #3
Thanks,
I understand the reasons.
but this is what causes my question:
"Expansion tanks are also required by state code if your system is closed in most of the states we work in."
The well pump tank is a bladder type with no check valve (check valve on the well pump in the well)
So I wonder if my system is "closed" .
Old 09-07-2008, 02:43 PM   #4
I may be wrong but I would consider it as a closed system. There would be no place for expanding air and water to go except back to your tank. This could cause some problems. Not enough pressure to trip your T/P valve but enough to cause undue pressure on the system.
Is it worth having my lawn sprinker system professionally closed for winter? J187 Landscaping & Lawn Care 9 02-06-2009 03:12 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
