Clogged Steel Pipe Under Cement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2011, 09:44 PM   #1
Clogged steel pipe under cement floor
Hi,
I have a clogged 4" pipe under our cement floor. The pipe runs under the floor for about 6 ft before connecting with the rest of the sewage lines. If I run a snake into the pipe I can only get it in about 24" and that's it. It hits something absolutely solid. I've partially cleared it, but we are having water back up continually in the basement.
I need advice. I am tempted to remove the kitchen cabinets and take a sledge hammer to the floor and attempt to replace the whole pipe up to where it connects to the others. Does this sound like a wise thing to do? I have never worked on steel pipes under concrete before so I have no idea what I would be getting into.
The house is 42 years old. I'm hoping for some answers soon, thanks.
dberladyn is offline   Reply With Quote
Old 07-05-2011, 10:20 PM   #2
Screw it. Time for a plumber on this one.
Old 07-06-2011, 07:42 AM   #3
Plumb or Die!
Yeah, better get a pro with the right kind of snake. Call a guy that has a camera, too. Just cause the snake has cleared any debris doesn't mean you've solved the whole problem.
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
dberladyn (07-06-2011)
Old 07-06-2011, 08:13 AM   #4
Thanks, I had a plumber over last night. He snaked it, I didn't realize the machines you guys have. Stupid for what I was thinking, but then that pipes always been a problem, it's never been snaked like that before. Hopefully it stays clear.
Thanks again.
Cement floor ideas World B Flooring 1 02-28-2011 01:42 PM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 08:54 AM
Cement floor dust diyhopeful Flooring 1 09-28-2009 06:10 AM
bathtub on cement floor kodeblue Kitchen & Bath Remodeling 2 05-26-2009 09:26 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
