Clogged Sewer Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2013, 01:31 PM   #1
Question
clogged sewer pipe
We have just replaced a section of pipe going from our toilet to the septic tank and it has backed up but slowly drains so we believe it has a clog but somewhere in the pipe between the new section and the tank, we have tried draino and plunger but still has not cleared...any tips?
Valderg is offline   Reply With Quote
Old 05-23-2013, 02:12 PM   #2
Rewards Points: 40
Some more information and background may be useful:
  • Why was that section replaced?
  • Did you replace it yourself?
If for some reason you really feel it is a clog, you may need to rent a power snake and run it through a clean out beside your toilet. If no clean out port is available, remove the toilet, and run the snake in the line in the floor.
Before anything, though, some more information would help.
CamaLamaDD is offline   Reply With Quote
Old 05-23-2013, 02:17 PM   #3
Rewards Points: 37
Did it back up before you replaced the pipe?
TOOL82 is offline   Reply With Quote
Old 05-23-2013, 10:00 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Draino is going to ruin that new pipe you just put in.
Journeyman Plumber
Tags
clog , drain , pipe , septic tank , sewer
(Louisiana) What size pipe Sewer, Drain and fresh water supply lines cmb7684 Plumbing 0 04-23-2013 05:54 AM
sewer vent pipe Q! obsidian231 Plumbing 0 07-06-2011 11:08 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
