Clogged Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2011, 01:46 PM   #16
Sorry for assuming you were being rude! I meant thousands on replacing a line! lol I know it is only a couple hundred for the camera. It is what we will probably end up having to do, we just really wanted to see if this was a "fluke" or if it is indeed backing up full force again. I do thank you for responding to me. Even if I thought you were being rude
adowling is offline   Reply With Quote
Old 06-28-2011, 02:51 PM   #17
Rewards Points: 1,214
I think most people on here just get frustrated on here when someone asks questions and good answers are given and the person that asks the questions don't follow what was answered. Very frustrating but that's not the answerer's problem all we can do is just give good answers to the best of our ability and the questioner can do with the info as he likes.
COLDIRON is offline   Reply With Quote
Old 06-28-2011, 03:05 PM   #18
Homerepairguy's Avatar
Rewards Points: 990
If you do have your drain camera'd, I wonder if it would be possible for the camera guy to draw his best guess as to the path of the drain? If it's possible, it will be a tremendous help to you if/when you have to dig where a possible problem might be.
Or maybe a drawing with dimensions is standard procedure? I donno since I never had a drain camera'd. Just throwing this out there in case it helps.
HRG
Homerepairguy is offline   Reply With Quote
Old 06-28-2011, 07:16 PM   #19
Owner
LateralConcepts's Avatar
We aren't avoiding a known problem. We don't know what they problem is. We are trying to get to the problem starting with the cheapest route first. I am pretty sure that is how most people handle problems to begin with. No one goes out and buys a new car when all the old one needs is a new wiper blade, right? Geez.
Running a camera IS the least expensive way to properly diagnose and locate the problem.
Then you can make an educated decision on the remedy. Either get multiple bids from quality contractors or fix it yourself.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 06-28-2011, 07:37 PM   #20
Owner
HRG
HRG - With proper equipment, the camera head has a built in sonde which sends off a signal to a locator above ground. It gives you the exact location and depth of the line. It can then be flagged, painted, or triangulated.
adowling - If you do pay to have it video inspected and located; if at all possible, find a company the specifically specializes in inspections and locates. By informing a plumbing company with a backhoe that you'll be getting multiple bids, their locate may not be as "accurate" as you had hoped or paid for.
Lateral
(208) 818-8241
The Following User Says Thank You to LateralConcepts For This Useful Post:
Homerepairguy (06-28-2011)
Sewer line material help detroit_fan Plumbing 6 05-09-2011 12:12 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
Dynamics of 3" vs 4 " main sewer line 4just1don Plumbing 4 01-07-2009 08:01 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
sewer main line repar Babar Plumbing 1 01-26-2004 07:39 AM
