Clogged Kitchen Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2009, 06:14 PM   #1
Clogged Kitchen sink drain
We came home from vacation to water on the floor-- The kitchen sink won't drain. So far, we have used a plunger; taken apart the pipes under the sink; used a blower and wet-vac; used a snake, which would only go about 10 feet. We're thinking to dig right outside where I think the pipe comes out of the house.. ANY SUGGESTIONS????
hornsby is offline   Reply With Quote
Old 07-23-2009, 06:40 PM   #2
Rewards Points: 1,452
Was it working well before?
Do other drains in the house still work well?
Do you know what route the kitchen drain takes?
There should be clean out plugs here and there on the drain pipe as it makes its way in the basement to the exit from the house. Putting the snake in these is often easier than trying to get it down from a sink or bathtub. This also can help narrow down on where the clog is.
Old 07-23-2009, 10:46 PM   #3
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
Kitchen sink drain
I think it's about time to call in a professional plumber
with the right kind of professional power snake ! ! !
Unless you have very unusual plumbing your drain should run
under the floor over to the nearest bathroom where it ties into the main sewer ! !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
venting kitchen sink drain illinifan Plumbing 2 05-03-2009 08:26 AM
Kitchen remodel, sink drain rework pinkertonpv Plumbing 3 02-18-2009 11:06 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 06:59 PM
