Old 10-13-2012, 10:11 AM   #1
Clogged kitchen sink
We've used drain cleaner 3 separate times. Removed under sink pipes and run a snake through. Brought up a small amount of gunk with that. boiling water several times. Plunged it as well.
Sabbey is offline   Reply With Quote
Old 10-13-2012, 10:32 AM   #2
Little late now but never a great Idea to start with a drain cleaner.
Just remove the trap under the sink and clean that out, if it's clean then leave it off and remove the pipe sticking out of the wall and run a snake down the elbow behind the wall.
Be very careful since you already have dumped a caustic liquid down the drain.
Old 10-13-2012, 08:29 PM   #3
Need more info, what size and type of snake? How badly is it clogged? Do you have a garbage disposal?
Off hand, I would remove the trap, snake the line as far as your snake will go, and then follow that up by flushing the pipe with a bladder such as a drain king. That usually does the trick for most of our units, but we're using a powered snake.
It's a kitchen sink drain, so odds are it's grease that's clogging it, if you still can't get it you might call around to see if a proper drain cleaner can jet the line.
AZJefe is offline   Reply With Quote
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 11:13 PM
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 6 09-22-2010 06:43 PM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 10:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
