Clogged Garbage Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2012, 09:02 AM   #1
Question
clogged garbage disposal
Water backs up at the garbage disposal and will not drain until the disposal is turned on. I've made sure the sink drain was not clogged, and even used a plunger on the disposal.
Otherwise the disposal works fine so I'm not sure what else could be wrong. Any thoughts?
srodie is offline   Reply With Quote
Old 03-20-2012, 06:31 PM   #2
DIY staff
Rewards Points: 7,174
Your drain is running slow----
Remove the P-trap and clean that out ---rodding the pipe into the wall would also make sense as long as the P-trap is off.
Old 03-20-2012, 06:40 PM   #3
Owner
LateralConcepts's Avatar
Is this a single or double basin sink? If it's a dual basin, does the other side drain properly?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
plummen (03-21-2012)
Old 03-20-2012, 08:04 PM   #4
The entire drain appears clean since the water clears out once the disposal is turned on.
It's a single basin with the disposal at the drain. The disposal doesn't allow the water from the basin to drain until it is powered on.
Old 03-20-2012, 08:33 PM   #5
DIY staff
Post a picture of the piping---I still bet it's a slow drain---
Could be clogged
Might be piped wrong
The disposer pushes the water like a pump---it would drain by itself if the pipe is flowing freely.
Old 03-21-2012, 07:17 AM   #6
Rewards Points: 1,214
Make sure you use plenty of water when grinding and run water for a while after to clear the lines.
COLDIRON is offline   Reply With Quote
Tags
clogged disposal , clogged sink , disposal
Clogged Garbage Disposal Dave in Michigan General DIY Discussions 2 08-08-2011 01:35 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
garbage disposal clogged amakarevic Plumbing 1 03-31-2009 02:16 PM
