Old 05-08-2010, 10:43 PM   #1
Clogged Faucets
We just had plumbing work done. While the water was off, a city main broke upstream. When we turned our water on, sediment was pushed into our plumbing. Most fixtures work fine, but our kitchen and bathroom faucets are clogged. We have already checked the aerators and replaced the bathroom faucet and these two are still clogged. We are still getting sediment a week later, but these are the only real trouble spots. Is it in the line? We suspect that the clog is in a turn in the line but are not sure where. Does anyone have any ideas as to how to clear this? Are we doomed to cut the line and hope to find the clog? Help! Thanks in advance.
Rich
richie11 is offline   Reply With Quote
Old 05-09-2010, 12:34 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Clogged Faucets
The sediment is most likely trapped in the shut-off valves or the faucets themselves.
Turn the shut-off valves off, disconnect the lines at the faucet, aim the lines into a bucket and turn the water on briefly to flush out the shut-off valves and lines.
Then, with the water still turned off at the shut-off valves, reconnect the water lines, disassemble the faucets, put a towel over them, and turn the water on again very briefly to flush out the faucet valves.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
plummen (05-09-2010)
Old 05-09-2010, 12:56 AM   #3
Clogged Faucets
Ok, I will try flushing out the supply lines first and if that doesn't work then disassemble the faucet. Do you mean take off the handles and pull out the cartridges and remove the center spout and the spout bushing? This is for the kitchen which the faucet is 4 years old.
Old 05-09-2010, 11:52 PM   #4
Clogged Faucets
The low flow diverter under the bushing in the spout was fouled. I cleared the supply lines as recommended and pulled the handle cartridges. They were ok. Thanks for your help and advice. I am learning so much!!
Toilet Fully Clogged ... still badgerbd Plumbing 4 03-16-2010 11:00 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 09:28 AM
Kohler wellworths Clogged Chemist1961 Plumbing 20 01-11-2009 08:43 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 04:32 PM
Repair/Rebuild antique faucets bofusmosby Plumbing 8 11-25-2008 06:59 PM
