Clogged Drain Tile - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2016, 08:15 PM   #1
Rewards Points: 34
Clogged drain tile
Looking to get some advice before moving forward. After heavy rains, water rushes into the window well drain and the ground is soggy in that area.
If you look at the two pictures in the link, I have two corrugated pipe inlets into my sump pump. This pictures was taken during heavy rains. The one on the left has no water coming out. The one on the right appears clogged with clay.
The house was built in 2001 with a drain tile system. I am not sure if both those pipes goes around the perimeter of the house or if one pipe is in the interior and one is for the exterior.
Plan A: Rent a snake and clear both pipes as far as the snake will go.
Plan B: Dig and replace as much of the corrugated drain pipe/tile as possible. Will I need to break the concrete near the sump pump to replace the part of the pipe or can I use a connector on the outside of the wall?
Thanks and look forward to your advice!
https://imgur.com/a/6vzxE
untilcomplete is offline   Reply With Quote
Old 08-16-2016, 04:41 PM   #2
Rewards Points: 2,040
Re: Clogged drain tile
Snake it to get it open then have it jetted to clear any mud. You apparently do not have it embedded in gravel for 12 inches our better.
Ghostmaker is online now   Reply With Quote
Drain tile in basement diychat09 Concrete, Stone & Masonry 12 01-28-2016 06:39 PM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Floor Drain P-Trap clogged, maybe grout? waistdeep Plumbing 1 02-16-2012 03:39 PM
Interior Basement Waterproofing Approaches - WaterGuard Vs. Schedule 40 Drain tile sconley Building & Construction 6 05-04-2011 10:03 AM
