Old 07-03-2009, 05:17 PM   #1
Default clogged drain in laundry room
I have removed the j- pipe and the clog is in the pipe from there to the wall pipe. at the wall there is a T with the drain from a bathroom above. the pipe has been there since the house was built 40+ yrs. i have tried spraying WD 40 but can not get it to loosen. anything else that will help loosen it. the clog is in the pipe and i have tried a snake but can not get it out. Help!
soccerfan is offline   Reply With Quote
Old 07-03-2009, 07:53 PM   #2
Yoyizit's Avatar
So it's probably lint that's blocking the pipe. . .I force hot water into the pipe using a garden hose and rags as a gasket, but this works better for totally blocked drains.
Yoyizit is online now   Reply With Quote
Old 07-04-2009, 08:10 PM   #3
Default drain
try a shop vac with a flex hose shoved in the tip. breid
breid is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through step one in making a sink drain better. The first thing we need to do is identify the problem when this sink fills up the water takes a very long time to drain out... Read More »
How to Unclog a Sink Drain
How to Unclog a Sink Drain by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through step to for making our sink drain better. Our next step is to remove this portion of that P trap to this I'm going to loosen both of these collars that holds the... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
How to Seal a Sink
How to Seal a Sink by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience. We just installed a sink from, probably from the fifties, into a house from the seventies. And what we want to do is seal everything up around the drain pipes and... Read More »
If your sink drain is clogged and you’ve already tried plunging it, which everybody knows how to do, you’re probably going to need to go a little further and snake out the drain line. I know this freaks out a lot of people, but it’s... Read More »
reclaiming bathroom cabinetry for laundry room - how to adjust to counter height? 7roses Carpentry 11 06-28-2009 09:07 PM
Trafficmaster Allure in Laundry Room - HELP! kt633 Flooring 0 03-22-2009 10:22 AM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 09:11 PM
Installing dryer outlet in laundry room ManMythLegend Electrical 11 07-13-2008 12:36 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 11:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
