Clogged Drain Or Clogged Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2013, 11:06 AM   #1
Rewards Points: 179
clogged drain or clogged vent?
Facts are clear. appliance in basement (washer) when trying to eject water after a couple of minutes said water starts backing up into BATHTUB which is 8 feet higher than where appliance in basement is.
So water moved UPHILL. If there was a clog in pipe downstream then of course the water would back up to least resistance opening (the bathtub). If the drain downline was clear, but the vent in attic was clogged can the negative air pressure actually pull the water upstream?
Yes the toilet gurgles too, but that could come just from air coming back from the clog.
i'm inclined to think its a clog downstream and not just a vent clog.
windowguy is offline   Reply With Quote
Use 4" steel vent as 2nd floor drain? ink Plumbing 7 12-14-2011 04:28 PM
Overlooked vent for shower, will it still drain? crankcase Plumbing 16 10-05-2011 08:41 AM
using section of pipe for both drain and vent amakarevic Plumbing 6 05-11-2011 12:20 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
