Clogged Drain In Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2011, 11:18 PM   #1
Clogged drain in bathtub
We had a plumber come out and unclog a drain in the bathroom sink on the main floor of our rambler house. There were no other clogged drains in our house. A few hours after the plumber left, I pulled the shower curtain back and I discovered our bathtub was full of black water and some kind of black sediment or something. We noticed that when running the water in the sink, the water was backing up into the bat tub. What is happening? Can we fix this or do we need a plumber again?
dc4669 is offline   Reply With Quote
Old 04-22-2011, 11:30 PM   #2
How full are we talking? 1/4 or 1/2 more less??? Also how far away is the sink from the bathtub drain? I think that if it was just the sink line that was clogged and he ran a snake or something down there he couldve just pushed the blockage farther down the line(just past the tub drain) and then left it there. If this was the case when he ran the water at the sink to see if it was still clogged the blockage would stop the water and it would then flow up the tub drain.
Im not sure if that will make sense to you but its as clear as I could put it.
ahrens is offline   Reply With Quote
Old 04-22-2011, 11:57 PM   #3
Thanks for your response. Your explanation makes sense. The bathtub was roughly 1/4 more or less full. The two drains might be about 5 or 6 feet apart on the surface. I don't know about the distance in the wall. I guess the bottom line is that the plumber should have kept running the snake. Besides checking all drains to make sure there are no clogs anywhere else, is there something else we should be aware of the next time?
Old 04-23-2011, 12:03 AM   #4
Hey no problem thats why everyone on here right Well Id assume you have a main cleanout somewhere in your sewer line. Rule of thumb when I was doing the plumbing thing was that if there was a clogged line we would snake and then open the clean-out and run the water to see what kind of flow we got and if it was still poor we would snake further and repeat that process until we got it.
Old 04-23-2011, 12:40 AM   #5
You are right! I know that's why I'm here. One more question. What is a cleanout and where is it normally located. Our house is over 40 years old.
Old 04-23-2011, 12:52 AM   #6
Does your house have a basement or crawlspace? It is generally close to where your sewer line leaves the house. I'll post a picture. It will generally look like this but can look different depending on what kind of piping is used. 40 years old it should still have a cleanout.
Old 04-23-2011, 01:23 AM   #7
Yes we do have a basement and a pipe that looks like your picture. You are so kind. Thanks again.
Old 04-23-2011, 02:23 AM   #8
Again not a problem, hope everything goes well
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 05:13 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 7 08-22-2010 11:11 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
