Clogged Copper Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2011, 02:50 PM   #1
I just installed a new refridgerator and hooked up the water line. There is no flow of water from the fridge. I unhooked the line from the wall and turned on the valve and there is no water coming out of the valve. I replaced the valve and there is still no water flow. It appears the copper pipe is clogged some where. Water flows fine from all the other faucets in the house. I don't know how this could have occured. Any ideas or suggestions on how to fix this problem? Thanks in advance.
geza is offline   Reply With Quote
Old 12-31-2011, 02:58 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
What type of valve,, saddle on pipe, angle stop, ball, gate ??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-31-2011, 03:05 PM   #3
It's a quarter turn straight stop valve.
Old 12-31-2011, 05:20 PM   #4
Rewards Points: 1,216
Follow the line from the valve back to the line it comes from and see if there's another shut off there.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
ben's plumbing (12-31-2011), plummen (12-31-2011)
Old 12-31-2011, 07:55 PM   #5
The line disappears into the wall, no way to follow it. I don't believe there is another valve as we shut off the valve at the wall when we moved the old fridge out.
Old 12-31-2011, 08:10 PM   #6
biggles's Avatar
if your copper they might of used a piercing valve but there is another valve after the wall if your galvinized then it's a reducing situation to get onto it(cold water)
Old 12-31-2011, 09:48 PM   #7
Rewards Points: 13,960
More likly a kinked line then a pluged one.
You did double check to see if water comes out of the valve with no line connected right?
May be simpler to just install a new line.
Old 09-03-2012, 01:02 PM   #8
In my case the water line for the fridge had a shutoff valve, the pipe went up the external wall into the attic, down a internal wall where it was connected to another shutoff valve under the kitchen sink. Imagine that.
aa3815 is offline   Reply With Quote
Old 09-03-2012, 07:16 PM   #9
Bombastic Idiot
notmrjohn's Avatar
And water comes out of the copper pipe when valve is removed? And the water ran fine with the old fridge? And you didn't kink copper while removing old or installing new fridge. Was the old valve ever off the copper during any of this fridge moving? Its a slab foundation isn't it? Who knows where other end is, it was there when you moved into house? My washer and fridge are back to back so I poked a hole thru wall and branched off washer copper.
notmrjohn is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
copper pipe vs pex I'm in trouble Plumbing 4 06-27-2010 11:42 PM
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 06:25 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 06:38 PM
