Clogged Cold Water In Bath Tub Tap. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2010, 10:46 AM   #1
Angry
Clogged cold water in bath tub tap.
Having an issue with the Tap on a bath tub. It's one tap that controls both hot and cold water. I am not getting cold water out of it. Dismantled it but can't see any obstructions. What can I do without having to tear up the bathroom. Stumped. Thanks
MakingitWork is offline   Reply With Quote
Old 11-09-2010, 05:25 PM   #2
Rewards Points: 150
Without knowing what brand and model you have it's almost impossible to give an answer, need more info.
braindead is offline   Reply With Quote
Old 11-09-2010, 05:51 PM   #3
I as braindead said, I also would wonder if you have galvanized pipe, and have you done anything with the plumbing recentaly?
I would turn off the water, pull the cartridge out, close the curtain and then turn the water on for a few seconds to let it purge itself out. if that dont work then we need to get technical
Ltnicks is offline   Reply With Quote
Old 11-09-2010, 06:36 PM   #4
I agree, shut off the hot water at the water tank, shut off the main water and dismantle the valve. if you get cold water coming out of the valve when you turn it back on, then its the cartridge. if nothing comes out you're gonna have to chase the water line back to something you know works and replace the stuff in question
the_man is offline   Reply With Quote
Old 11-10-2010, 08:07 AM   #5
Plumb or Die!
If it's single handle, 90% chance it's the cartridge.
plumber666 is offline   Reply With Quote
Old 11-12-2010, 12:24 AM   #6
Thank you for the help. If it's the cartridge, can I get new one?
Tags
bath tub , plumbing repair , taps
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Only hot or cold water DiyPadawan Plumbing 8 10-20-2010 09:13 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
