Old 09-28-2011, 09:42 PM   #16
AlbacoreShuffle's Avatar
clogged the boyfriends toilet... help?
This thread should be on " Best of Craigslist "
AlbacoreShuffle is offline   Reply With Quote
The Following User Says Thank You to AlbacoreShuffle For This Useful Post:
shadetree (10-03-2011)
Old 09-28-2011, 09:43 PM   #17
Stick your hand down into the whole and you should be able to grab chunks of glitter out until the clog is cleared.
OhioHomeDoctor is offline   Reply With Quote
Old 09-28-2011, 09:47 PM   #18
fml
i'm not glittered up.... the bathroom is "glittered" up.... and yeah, so, he doesn't have to deal with my glitter and........
so...... visuals make life different. you hear about tsunami's and stuff. cholera in hati. you might see pictures in media and hear stories but actually being surrounded by something like that is entirely different. you don't have to guess about the smells, the gross stuff they leave out of published media.... after the hurricane katrina, i went down to new orleans to help rebuild, clear stuff away, strip houses of dry wall, flooring, stuff. not that i am comparing this on levels of emotional stress to katrina or anything, that's not the point... when you think of a clogged toilet, you think of your own clogged toilet and barely remember much besides you're glad it worked out quickly... but imagine my clogged toilet. don't you think its really unattractive to imagine someone else's clogged toilet? now, consider actually seeing it, smelling it (i just smell drano like stuff, honestly), having to deal with it? it's just one of those things you can't unsee or unexperience.... a glitter clogged toilet. great.
fml is offline   Reply With Quote
Old 09-28-2011, 09:48 PM   #19
fml
we're not on craigslist. derp.
Old 09-28-2011, 09:56 PM   #20
KemoSabe
loneframer's Avatar
Well, it's either unclogged, or really clogged......
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 09-28-2011, 09:59 PM   #21
Or there was a glitter explosion when the bf got home.
Old 09-28-2011, 10:00 PM   #22
Doing it myself
Alan's Avatar
The best way I find to use the plunger is to gently create a suction against the bottom of the bowl and trap opening, and then PULL with force. If it's clogged, trying to force it through with the plunger usually doesn't work, and MOST people don't use this method because it makes a mess.
What would work better is a closet auger, and if you don't have one, I suggest you get one. They're not that expensive. Save your pennies. For now, just keep plungin away.
Journeyman Plumber
Old 09-28-2011, 10:00 PM   #23
fml
Got it!
The Following User Says Thank You to fml For This Useful Post:
Sir MixAlot (09-28-2011)
Old 09-28-2011, 10:01 PM   #24
Drywall and Painting Pro
Sir MixAlot's Avatar
Definitely try and flush it again.
-Paul
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 09-28-2011, 10:03 PM   #25
Originally Posted by fml
Got it!
Congrats. Buy some odoban in the morning.
Old 09-28-2011, 10:07 PM   #26
KemoSabe
loneframer's Avatar
fml, glitter will never be the same in my eyes. Thanks for that.
Old 09-28-2011, 11:16 PM   #27
Old School
Willie T's Avatar
Three rules for "tough turds".
1. Flush often as you sit there. Every time something happens.
2. Never flush anything except toilet paper... no Kleenex tissues, no paper towels, and of course no feminine hygiene products.
3. Use only "Angel Soft" toilet paper. (Yes, this is a serious recommendation.)
Also, you might flush a cup of Copper Sulfate crystals down the toilet every six months. This kills any possible tree root infiltration (it happens a lot) Buy the stuff at a Nursery, or check with a plumbing supply house.
Willie T
Old 09-28-2011, 11:58 PM   #28
To test whether the toilet is still clogged ...
Lift off the toilet tank cover.
Flush the toilet -- Watch the bowl and if it threatens to overflow then reach into the tank and press the flapper back down. Then quickly turn off the shutoff valve under the toilet so the small amount of water put down the tank overflow tube during tank refill doesn't break the camel's back and make the bowl overflow.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 09-29-2011, 12:14 AM   #29
General Contractor
Don't shut the water off. Flush the toilet again to get the water in the bowl all the way to the top, this builds up pressure to help unclog it. Then get the plunger and give it rapid aggressive strokes, about three a second. I've never not been able to unclog a toilet this way.
KennMacMoragh is offline   Reply With Quote
Old 09-30-2011, 07:02 AM   #30
the Musigician
DangerMouse's Avatar
Originally Posted by fml View Post
he doesn't need to know how my "massive" dump caused water to leak from the bathroom into the basement on top of some random electronics parts.... now does he?
I hope this is ONLY from overflow, and not a leak.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Tags
toilet clogged plunger
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet Fully Clogged ... still badgerbd Plumbing 4 03-16-2010 11:00 PM
Toilet clogged and leaked downstairs a bit, is this bad? Red Squirrel Plumbing 4 01-15-2010 06:16 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
