Clogged Bathroom Sink, Help!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2007, 05:21 PM   #16
Eibwen
The acid should only eat organic material.. My main concern would be any other drain cleaners you already have in the pipe.
But it works so good the one time that I did use it that I pulled the label off the empty bottle and pasted it to the tool box lid where I keep my plumbing tools and copper fittings.
My other suggestion would be the hose end pipe clearing fittings that work off the water pressure. Swells up when the water is on and builds up a pressure to push the clog out assuming its not roots etc. I have gotten these pretty far down a 1 1/4" pipe and if you can get it past the vent it may clean it out. Just need to be wary of any chemicals already in the pipe from previous attempts.
Let me know how it turns out for ya.
Sammy is offline   Reply With Quote
Old 11-11-2007, 09:37 PM   #17
That one Guy's Avatar
Any acid based chemical is not good. Non acidic drain openers rarley ever work and there real purpose is to maintain a clean drain after clearing it with the snake.
You could try a hand snake with a 1/4" cable but you might want to cut off the stupid bulb head it comes with and bend the end at a 45 degree angle or curl it slightly. I have an ericson crawl head wich is alittle different but I only use it for special situations. Any pistol grip style machine with a 1/4" cable is the tool in need here. I have a General Super V and a Rigid K-38. These are expensive though for one time use.
Or call a drain cleaning company, usualy the snakes at most rental yards are used and abused and they are odd sizes that no pro really uses.
Any reputable company should offer a guarantee and get through that lav sink drain fairly easy. Hopefully there are no striaght tee's!
That one Guy is offline   Reply With Quote
Old 11-12-2007, 07:52 AM   #18
Rewards Points: 342
I have a hand snake with a plastic sleeve. First, I am assuming remove the plastic sleeve. Next why remove the bulb? Third, how much to bend the end of the snake?
tripower is offline   Reply With Quote
Old 11-12-2007, 08:04 AM   #19
Rewards Points: 342
OK, the hand auger (snake) I can only get to go a foot or so. The snake makes an immediate left hand turn, goes a little bit and then stops. It does not go down. This is not an obstruction it is the pipe. I have hand twisted in a circular motion, I have bend (slightly) the snake, but i cannot get it to go down.
Old 11-12-2007, 12:03 PM   #20
Custom Cabinet Maker
ROTO ROOTER At this point is is clear that this problem is way beyond a simple "snake it" and done. With all the effort etc you are going thru with NO results it is going to be way way cheaper and easier to just call and get em out there
skymaster is offline   Reply With Quote
Old 11-12-2007, 03:48 PM   #21
Rewards Points: 150
It is possible then that your drainpipe straight tees into a stack. Do you think it might be possible to go onto the roof and snake it from the vent?
scorrpio is offline   Reply With Quote
Old 11-12-2007, 04:21 PM   #22
Rewards Points: 342
Great News!!!
I got it! Thanks to everyone and especially "That One Guy". When I cut the bulb head off of my snake I noticed I had a lot more maneuverability. I was able to quickly get it down to clog. And I was pulling out tufts of hair. Once I punched through the clog the rancid water in the pipe drained through allowing me to send a healthy does of hair clog removal gel. Anything that i was putting down the pipe was never getting anywhere near the clog because there was so much water left in there. So again, thanks to everyone!
Old 11-13-2007, 09:21 PM   #23
Good news! Glad I could help.
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 11:28 AM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 09:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 11:24 AM
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 05:47 AM
