Clogged Bath Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-14-2010, 10:56 PM   #1
clogged bath tub
hey i know a ton of people have posted under clogged bath tub. my friend and i have pulled the overflow and are trying to snake with a 1/4" snake. sadly though after fighting with it 4-5 inches in the snake is visible in the drain and starts to coil up.
looking at diagrams online that shouldn't be happening it should go straight to the p or s trap.
help
how do i get it to the trap not the main drain?????
brokenpipe is offline   Reply With Quote
Old 09-15-2010, 06:05 AM   #2
You may be dealing with a cast iron drum or bell trap. Nearly impossible to get a snake thru them. If that is where your clog is, better to replace it with a P trap. Also not a fun job due to space restrictions, trying to get two hands and tools in 1 sq inch of space.
Old 09-15-2010, 09:51 AM   #3
Rewards Points: 352
spin the snake the other way when you feed it in
plumberinlaw is offline   Reply With Quote
Old 09-15-2010, 05:09 PM   #4
There's two of you, cover up the overflow and plunge that drain. When one gets red in the face, switch over....... you'll get it.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Tie into existing bath GFI circuit for new basement bath GFI? 8roty Electrical 8 07-27-2009 11:38 PM
Kohler wellworths Clogged Chemist1961 Plumbing 20 01-11-2009 07:43 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
