Clog At Toilet Drain Hole - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2012, 06:28 PM   #1
Clog at Toilet Drain Hole
I have a toilet in my hall way that over time will clog up at the drain hole. By this I mean it will work for several days and then suddenly I go to flush and water come out around the base of the toilet. When I remove the bolt and pull the toilet away the drain pipe is clogged.
Unlike a normal clog it does not overflow the toilet, then water come out around the bottom base of the toilet. I have replaced the wax ring many time and while I am not a plumber I feel pretty confident I am replacing it correctly.
You can flush it with no solids and it works fine. My back bedroom toilet works fine.
I guess I need to call a plumber but I wanted to see if anyone has some ideas or has run into this situation before.
Thanks!
Lpitt56 is offline   Reply With Quote
Old 12-30-2012, 06:44 PM   #2
Rewards Points: 13,296
Could be it was plumbed wrong in the first place, someone droped somthing in the toilet and it's stuck in the trap, pluged up vent, plugged up drain, failed drain field.
Just changing the wax ring as you found is not going to fix anything.
Old 12-30-2012, 08:46 PM   #3
DIY staff
Rewards Points: 7,174
You may have a bad flange--or you have failed several times with the wax ring---
A toilet will not leak from the base if the flange is good and the wax ring/toilet connection is done correctly--
I suggest you rod that line clean before you reinstall the toilet----Mike---
Tags
clogged drain pipe , clogged toilets , toilet
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Toilet drain damage pf22 Plumbing 2 07-26-2012 11:15 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
Toilet Only on Drain Line Perry401 Plumbing 1 09-27-2011 02:30 PM
What to cover the toilet drain hole with while doing renovations? RyanD Plumbing 4 06-15-2009 07:05 AM
