Old 04-08-2010, 01:03 PM   #1
Clicking sound when hot water turned on
Our hot water heater is in the attic above the MBR and master bath room. When the hot water is turned on, a clicking sound begins in the wall below where the hot water heater is located. It starts loud and then gets quieter. When the hot water is turned off, the clicking sound continues, first louder and then gets quiter (and less frequent) over a period of time and eventually stops. Any suggestions?
flarazorback is offline   Reply With Quote
Old 04-08-2010, 01:31 PM   #2
fabrk8r
fabrk8r's Avatar
I will assume you have copper water lines.
Inspect the places where the line from the water heater may be in direct contact with joists, floors or walls. Copper expands and contracts a lot with temperature change and will make noise as it slides along another surface.
If you find any places where there is contact you can isolate the pipe from the wood with armaflex or plastic pipe supports. It wouldn't hurt to insulate your hot water line with armaflex if there is none now.
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
flarazorback (04-08-2010)
Old 04-08-2010, 02:49 PM   #3
Thanks, I'll try it.
Water baseboards generating clicking noise Dezso3 Plumbing 1 01-15-2010 08:13 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
the sound of water.... mmhendrie Plumbing 5 04-25-2009 08:23 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
