Clicking Noise In Pipes When I Turn On Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2010, 01:24 PM   #1
clicking noise in pipes when I turn on hot water
I am experiencing a clicking (some might say a banging, but I think clicking better describes the sound) in my pipes when the hot water is turned on.
It starts out slow with a click every 4 to 5 seconds and slowly builds to a click every 1/2 second. The sound stops after about 45 seconds to a minute.
This only occurs when hot water is turned on. In my master bath, there are separate knobs for hot and cold and the clicking does not occur when the cold water is turned on. In all my showers there is only one knob and the clicking only occurs when the water is turned towards hot. This is occuring on both sides of my house. I have two hot water heaters. It also occurs when the dishwasher is turned on.
Can anybody tell me what is causing this. This has been occuring for 4 or 5 years - ever since I bought the house. The house is about 8 years old.
Thanks.
jbonecpa is offline   Reply With Quote
Old 08-30-2010, 01:42 PM   #2
PZ Reject...
pipes expanding when hot water is ran..probly the pipe is in a tight hole...try to trace it down...more than likely your just gonna have to live with it...
Rambo is offline   Reply With Quote
Old 09-02-2010, 02:38 PM   #3
You mean the holes where the pipes are drilled through the headers are too small to allow the pipes to expand when the hot water is run?
Old 09-02-2010, 02:51 PM   #4
fabrk8r
fabrk8r's Avatar
This type of problem has been talked about numerous times just within the last few months.
If you use the search feature I think you'll find a lot of ideas to consider.
Here is one recent thread on the subject: Wood Pecker In Wall or Something Worse!!!?
And another: Tapping/Knocking Noise in Ceiling/Floor (could it be pipes?)
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 02:53 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 09:15 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
