Clicking Inside Walls After Use Of Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2008, 07:47 AM   #1
Clicking inside walls after use of water
We recently moved (45 days) into our home in Florida with 12' ceilings and the hot water heater in the attic. Whenever we use the water, we hear a clicking noise in the ceiling/wall but only in the area above the master bathroom and office. At first we thought it may be a drip, but the clicking changes in tempo and can get very fast, it has also been happening the whole time we have been here and there are no water spots. Any thoughts??
Jax newbie is offline   Reply With Quote
Old 02-21-2008, 07:59 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
That is simply hot water flowing through plastic piping, causing expansion and contraction "clicking" noises. No harm, no leaking, just clicking.
My ABS black plastic drainpipes have been doing the same thing for more than 30 years, and we've never had a problem.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-21-2008, 08:05 AM   #3
Thanks! That is a relief!
Old 02-22-2008, 07:37 AM   #4
biggles's Avatar
if it is concentrated in the same area of the ceiling or wall it could be as simple as a support bracket for the pipe and as you open the water to use the pressure change makes the pipe bounce a little ...giving you that clicking if it is constant on the hot but not on the cold side its probably that
Old 02-23-2008, 12:48 AM   #5
Master Plumber
Rewards Points: 150
It happens on copper hot water pipes too.
jpplumber is offline   Reply With Quote
Using OSB on inside walls handymanII Building & Construction 8 03-23-2010 08:24 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Old Brick House inside walls rick32 Building & Construction 6 11-08-2007 06:49 PM
Clicking sound in walls leted_82 Plumbing 7 10-16-2007 06:25 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
