Clearing Out Clogged Downspout Extensions - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2011, 05:22 AM   #1
sweaty
Rewards Points: 276
I have two downspouts that connect to flexible black extensions. Those extensions are buried and lead to my sump pump. During yesterday's storm, I noticed that NO water from them went into my sump pump. I checked outside and water was spilling over the top of the extensions.
I assume roots have clogged them up. Can a plumber clear these out without tearing the tubes?
sweaty is offline   Reply With Quote
Old 08-08-2011, 07:12 AM   #2
DIY staff
Rewards Points: 7,174
Possibly----have you disconnected the down spouts and checked to see is twigs and leaves are plugging it up right at the connection?
That is a very unusual set up----why is your roof draining into your basement like that?
Old 08-08-2011, 10:48 AM   #3
sweaty
Rewards Points: 276
I don't know why. It was built like that.
Old 08-08-2011, 11:24 AM   #4
Rewards Points: 352
You should divert all outside water away from the house by a minimum of 10'. How much water would your basement hold if your sump pump failed and all the water from the roof went into it?
plumberinlaw is offline   Reply With Quote
Old 08-08-2011, 12:01 PM   #5
Rewards Points: 87
I wonder if the OP's property isn't all pitched badly, and the individual who did this figured it was the easiest way to overcome the problem?
Regardless: ISTM a disaster-in-waiting. A power or pump failure at the wrong time, and...
I would recommend finding out why what was done was done, and fixing that. Leading roof run-off into the home strikes me as a Particularly Bad Idea.
More Power! is offline   Reply With Quote
Downspout over lower roof smcclana Roofing/Siding 5 10-08-2010 01:20 AM
Toilet Fully Clogged ... still badgerbd Plumbing 4 03-16-2010 11:00 PM
underground downspout extensions blocked ibgyahoo General DIY Discussions 6 06-08-2009 12:56 PM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
underground downspout extensions joshm Roofing/Siding 3 05-20-2008 10:45 PM
