Clearing My Water Pipes So I Can Solder A Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2011, 11:46 PM   #1
Clearing my water pipes so I can solder a joint
How do I blow all the water out of my cold water pipes so I can fix a bad solder?
Fred1948 is offline   Reply With Quote
Old 02-26-2011, 11:54 PM   #2
Libertarian
I shut down all the water to the house and open every faucet in the house wide open. Once everything is drained, I just cut the pipe and let it drain into a bucket and fix the problem... sometimes I end up with a bit of water in my face when I cut the pipe but oh well it dries.
kurt2 is offline   Reply With Quote
The Following User Says Thank You to kurt2 For This Useful Post:
plumberinlaw (02-27-2011)
Old 02-27-2011, 05:40 AM   #3
Rewards Points: 264
sometimes I use a shop vac if I can't get it to drain completly
plumberinlaw is offline   Reply With Quote
Old 02-27-2011, 08:06 AM   #4
Just call me Andrew
Rewards Points: 1,012
You can stuff some white bread in the pipes to hold the water back while you solder. It will dissolve when you turn the water back on. Don't use wheat bread.
Andrew
secutanudu is offline   Reply With Quote
Old 02-27-2011, 11:48 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 2,534
Ayuh,... That's what I do....
just be sure to take the aerators off the spouts downstream so's to flush the bread out, without pluggin' 'em up...
Old 02-27-2011, 11:53 AM   #6
Just call me Andrew
Originally Posted by Bondo View Post
Ayuh,...
Ok, I gotta ask....why do you say this at the beginning of all your posts!?!?
Andrew
Old 02-27-2011, 12:12 PM   #7
Owner
LateralConcepts's Avatar
I'm curious too.. guessin' though he types like he talks. Kinda like the way I drop all the G's at the end of words... and use a lot of conjunctions.
Ayuh, like huntin', fishin', campin',... that'd be my guess
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 02-27-2011, 12:14 PM   #8
http://www.urbandictionary.com/define.php?term=ayuh i lol'ed at #4
the_man is offline   Reply With Quote
Old 02-27-2011, 12:17 PM   #9
Owner
Originally Posted by the_man View Post
Lol nice!
Lateral
(208) 818-8241
Old 02-27-2011, 12:24 PM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,024
Journeyman Plumber
Old 02-27-2011, 01:48 PM   #11
Bondo's Avatar
Ayuh,... I guess you guys found the google answer to my Downeast dialect,...
Wicked Bad, eh,..??
Btw,... I decided not to wait fer that Steve King novel,....
Old 02-27-2011, 02:15 PM   #12
Hvac Pro
Rewards Points: 1,396
And here I thought us Canadians talked funny, Eh.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
clicking noise in pipes when I turn on hot water jbonecpa Plumbing 3 09-02-2010 02:51 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
do soldered joints ever break after ? amakarevic Plumbing 8 12-12-2008 11:16 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
