Clearance Between Radiator Pipe And PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2011, 02:01 PM   #1
Rewards Points: 1,062
Question
clearance between radiator pipe and PVC
is there a minimum (recommended/required) clearance between radiator galvanized steel pipe and PVC pipe (as to avoid melting PVC)?
Old 09-27-2011, 03:15 PM   #2
Civil Engineer
Rewards Points: 4,940
Unless you are running steam, you are not going to melt PVC even if the PVC touches hot water piping. You will soften it however, and it may deform. I don't know if there is a code reference, but I would keep the PVC at least 6 inches away.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
amakarevic (09-27-2011)
