Old 10-04-2011, 05:33 PM   #1
Question
clearance b/ween copper water supply and drywall
i was wondering if there is a minimum clearance between copper water supply inside a wall and drywall. e.g. do the pipes have to be right in the middle (e.g. approx 1.5" away from the backs of both drywall panels) or can they even be touching drywall on one side.
thanks
Old 10-04-2011, 06:19 PM   #2
Mark Potter's Avatar
thanks
making the depth about 2" in a 2x6 framed wall unless there is a 1 1/2" drain pipe in the way witch will be in the middle.. Then it gets complicated if so this feed is 1 1/2" feed your installing?
I wouldn't suggest putting it close to the wall anywhere in the middle
HP Properties Capital Projects
Mark Potter is offline   Reply With Quote
Old 10-04-2011, 10:09 PM   #3
Doing it myself
Alan's Avatar
My plumbing code doesn't have a minimum clearance. For all that it matters you can run the piping exposed and secured against the drywall. It just doesn't look as pretty.
Sometimes there's just not room in the middle.
I would reccomend however that if you do have to run it against the sheetrock to secure it in a manner so that it won't slap the sheetrock if you get a little water hammer going on in there.
If you can hold it back a little bit, and put a bit of insulation between the pipe and the sheetrock, that would be even better.
Journeyman Plumber
Old 10-04-2011, 10:26 PM   #4
Not for heat pipe as it expands the copper can't be strapped tight .
Old 10-04-2011, 11:29 PM   #5
call me E
TheEplumber's Avatar
Don't forget the nail plates
Electricity in water supply BimmerRacer Electrical 5 02-02-2010 09:39 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Ground Main Water Supply? blueboy27 Electrical 17 11-04-2007 01:38 AM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
