Old 04-28-2009, 07:10 PM   #1
Clear Silicone instead of Plumbers Putty
can I use Clear Silicone instead of Plumbers putty on a garbage disposal? I live about 45 minutes from town and this is the only thing I have to put on it because it is leaking. If I can use this how soon do I need to replace it with plumbers putty if even at all?
jmacx81 is offline   Reply With Quote
Old 04-28-2009, 07:44 PM   #2
It would help if you would tell us exaxctly where the leak is
Is it under the flange in the bottom of the sink or on the trap so on and so forth.
al's sewer is offline   Reply With Quote
Old 04-29-2009, 07:14 AM   #3
The short answer is, no. It won't work, or not for long. There must be a hardware store closer than that, they have plumbers putty. I assume you have tried tightening the disposal clamp screws underneath??? You need to remove the disposal, throughly clean around the hole and reinstall with new putty. It doesn't take long and should fix the problem. If the disposal clamp is rusted, replacements are available at big box and some hardware stores.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 33 01-03-2013 12:58 AM
Plumber's Putty around sink flange DIYGST Plumbing 6 02-03-2009 08:18 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 11:23 PM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
Clear silicone caulk used instead of plumber's putty**HELP** hummin40 Plumbing 8 02-12-2008 02:59 PM
