Clear Silicone Caulk Used Instead Of Plumber's Putty**HELP** - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2008, 11:09 AM   #1
DIYAddict
hummin40's Avatar
Send a message via Yahoo to hummin40
Clear silicone caulk used instead of plumber's putty**HELP**
We have a bathroom sink that someone used a clear silicone caulk on the drain flange instead of plumber's putty. They left one heck of a mess all over the sink that I can't get off with anything on the market. I've even used a razor to try to scrape the mess off of the sink bowl itself. A salesperson at Lowe's recommended some gooey green stuff that I let sit for over 24 hours without ANY softening of the caulk. Is there anything else I can try? (besides hunting the plumber down and caulking HIM?)
Thanks in advance!
hummin40 is offline   Reply With Quote
Old 02-04-2008, 02:34 PM   #2
Joe F's Avatar
Rewards Points: 294
I'm surprised it's sticking that well to the sink. How about trying a scotch brite pad?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 02-04-2008, 02:57 PM   #3
DIYAddict
hummin40's Avatar
I think I started with one of those. I just finished reading a thread on here where some guy had the same problem with silicone in a tub. One suggestion was a sanding drill. Sounds like I'm stuck with a mess and I'm not alone.
Oh well, I tried. Thanks for your help, Joe.
Old 02-04-2008, 10:30 PM   #4
Send a message via AIM to Marlin
Usually it comes off pretty easy. This is why I recommend plumbers putty over silicon. They make a non-staining putty for plastics and porous stones.
Marlin is offline   Reply With Quote
Old 02-04-2008, 11:11 PM   #5
What about acetone (nail polish remover)
CathrynH is offline   Reply With Quote
Old 02-04-2008, 11:18 PM   #6
use a knife
u need to penetrate it first then start scraping, put your back into it
amdspitfire is offline   Reply With Quote
Old 02-04-2008, 11:36 PM   #7
new sharp razor blades and time have always worker for me.
dyier is offline   Reply With Quote
Old 02-04-2008, 11:58 PM   #8
Bathtub Refinisher
Use a scrap razor blade and remove as much as possible. Then take WD 40 and spray the area down. Now continue scraping the wetted area down with razor blade. It might take a couple of tries. Let us know how it works out.
tubguy is offline   Reply With Quote
Old 02-12-2008, 02:59 PM   #9
DIYAddict
hummin40's Avatar
Thanks everyone! Elbow grease, razor blades, WD40 and scruffies have taken most of the mess off. I appreciate your help!
Removing Silicone Caulk... BillK40 Painting 39 10-28-2013 02:35 PM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 07:32 PM
Bathtub Caulk billinak Remodeling 17 05-27-2007 09:34 AM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 09:45 PM
