Clear Plastic Hose On Gas Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2011, 08:04 PM   #1
Question
Clear plastic hose on gas water heater
I HAVE A REPAIR TO DO ON A GAS WATER HEATER, WHERE THERE IS A CLEAR PLASTIC HOSE COMING UP FROM THE PAN UNDER THE HEATER AND WAS ATTACHED TO THE TANK WITH SOME STICK ON CLIPS THAT FELL OFF. THE OTHER END OF THE HOSE HAS A RETAINING CLIP AT THE END AND I NEED TO KNOW WHERE IT SHOULD BE CONNECTED TO, AS IT IS JUST HANGING. APPRECIATE ANY HELP!!
elswami is offline   Reply With Quote
Old 11-10-2011, 08:35 PM   #2
Does that hose connect to the T&P valve?
Billy_Bob is offline   Reply With Quote
Old 11-10-2011, 08:46 PM   #3
is this a power vent water heater? some used to have a clear hose that attatched to a tee in the horizontal vent for condensation to drain through.
Old 11-10-2011, 09:55 PM   #4
Thanx DannyT.....it is a power vent as it has a ventilating unit on top, that vent out through pvc piping. The tank is in a tight corner so I'll have to look for the tee and reconnect. Thanks again DannyT...Billy Bob....
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
low pressure after hot water heater replacement tuffluck Plumbing 4 06-07-2011 03:14 PM
Why does my water heater smells like burnt plastic? Player Plumbing 2 07-12-2010 12:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
