-   -   clear the drain! (http://www.diychatroom.com/f7/clear-drain-96036/)
analogmusicman 02-20-2011 08:33 PM
clear the drain!
my bathroom drains clog up every 1-2 months,requiring a good dose of Drano. I don't think they should clog that often,but I guess I'll live with it. :) anyway,right now the plumbing is taken apart t'ill I get my new faucets installed and I thought I'd take the opportunity to maybe clean the rdain pipes a bit. I could put a hose in the drain pipe and blast water in there or maybe since I've got a compressor I could blast in some air. is that harmful to the drain pipes? should I just leave it alone?
BTW: there are 2 sinks in the bathroom,that drain into a common drain pipe. this may be where it's clogging. don't know but I DO know that when the bathroom was "done over" 20 years ago, pro's did the work so I assume it was done correctly.
tnx,
Leah Frances 02-20-2011 09:26 PM
Drains clog unless you only run water down them. Soap, hair, whatever eventually builds up and causes a clog. There are several EZ things you can do to prevent this from happening.
- Use a hair trap - it also will collect soap scum. Yeah they aren't pretty, but since I've been using one on my tub I haven't had a clog. And you can always hide it when company comes over.
- on a periodic basis run a good amount of HOT water through the pipes. I do this about once a month with a large pot full of scalding hot water (more often for my kitchen sink).
Good luck.
plumberinlaw 02-21-2011 07:33 AM
mmm! draino.I make part of my living from people who think draino will fix a underlying problem, cable the line and clean it correctly once and for all.
analogmusicman 02-22-2011 01:26 PM
it's clogging right at the wall. I'll take Leah's advice and pour scalding hot water in the drain periodically.
BTW: I also ran a "snake" in the drain for good measure:thumbsup:
tnx,
plumberinlaw 02-22-2011 10:00 PM
Did you pull anything back?
analogmusicman 02-23-2011 10:36 AM
only a bra and panties!:laughing: actually if you mean did anything come back out of the drainline? no. the clog was apparent when I pulled out the pipe that goes into the wall.
tnx,
Docwhitley 02-23-2011 12:48 PM
Liquid Plumber and Drano are horrible for your pipes but great for my wallet! every time they are used a little bit of the pipe is eaten away and eventually you will have a leak
What I like for sinks and the tub would be something like Biochoice or other natural enzyme that eats the soap scum... With out the scum hair will naturally pass by unless it gets caught on something (ex-Pop up assembly)
What I hate besides the two mentioned above- Anti-bacterial soap! It kills all the bacteria that would have feasted on the drain soap! All bacteria is not bad!
As far as Hot Water in the kitchen sink... Works great unless you have grease in the line... If you do be careful because this could actually cause grease to become a liquid and then solidify causing a blockage... hmmm wonder what would happen if you put dish detergent in with the hot water
analogmusicman 02-23-2011 09:16 PM
hey Doc, you saying the folks at "Draino" are lying when they claim that "Draino is safe for your pipes"?:no:
tnx,
Adam_M 02-23-2011 10:25 PM
I snake lines, but if it's a good chunk of hair you could use Zonk it's sold at home depot, it works great at burning the hair out. Just remember to use it in a ventilated room or better yet pour it down an leave for 15 minutes after which you can let the hot tap run an purge the line. It's not a product is be used all the time only when it's really thick.
Alan 02-24-2011 08:59 AM
tnx,
I would say that as well. Have you ever gotten that junk on your hands? It frickin burns. Hope none of your plumbing is plastic. :whistling2:
Docwhitley 02-24-2011 11:09 AM
Couple things I know about Draino
1- It burns
2- I have had a cable that was not rinsed after being used in Drano start to deteriorate.
3- It warns you not to have children, hands or face around this chemical when being used
I will not get into a battle over what they claim but I know when my guys do drain cleans they wear heavy gloves and a shield because of those chemicals
I do not like putting a chemical in a tub that I will bathe a child in.... Just my preference
If I am going to use something to help with clogs I use
vegetative liquid bacteria solutions
Preferred method for me is jetting
plumberinlaw 02-24-2011 11:38 AM
drains with draino cost more to cable, hard on equipment, dangerous for operator
