Cleanout Required? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 01:10 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
Cleanout Required?
I think I already know the answer......
This is the bottom view of one of master bath sink drains. It's about 6' to the intersection with the 2" line that will go down to the main 3" drain. I can get a clean out on this line...but I'll have to drill a hole in the blocking and put the end of it ouside under the cantilever of the 2nd floor...
My issue is that I have one more like it to install....the drain comes out right next to the PSL beam.....no room behind the cleanout.
Are there any options?
Old 10-23-2012, 08:35 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 678
With few exceptions, I am not required to install clean outs above the first floor.
You an put it in the vertical piping above the floor
Old 10-23-2012, 08:48 AM   #3
JOATMON
ddawg16's Avatar
Ok....that makes sense.....
Hence, if I had an issue...I remove the p-trap and snake from there?
Next question.....does that sink drain pipe need to be 2" or 1 1/2"?
I have 4 items to drain in that area....2 sinks, shower and tub....shower and tub will be 2" all the way to the ground...(and in one pipe).
I was just going to use a sweep T to add the sinks to the 2" line....
Hide cleanout plug behind drywall? TomU Plumbing 19 07-08-2016 01:50 PM
New construction outside kitchen cleanout blocked off? markbair Plumbing 0 08-05-2012 10:26 PM
Sewer cleanout - which side of trap? Ultrarunner2017 Plumbing 4 08-29-2011 08:56 AM
drain cleanout accessibility options acerunner Plumbing 14 07-07-2010 12:28 AM
Re-using a drain cleanout mpt1123 Plumbing 0 01-19-2010 05:45 AM
