Cleaning Sewer Lines With Pressure Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2009, 07:15 PM   #1
Rewards Points: 16
cleaning sewer lines with pressure washer
My sewer backed up the other day and I got it cleaned out using a balloon in the cleanout but would like to snake out the whole line now to make sure it won't happen again. I have a smaller ridgid power auger I bought from home depot that has worked on smaller drains from sinks and tubs but it's only 25 ft long and small diameter. I was looking at getting a bigger auger to reach all the way to the street. They are around 500 bucks for something that looks decent. It would cost about 100 bucks to rent one for a day so I would rather just buy something so I have it. While searching for sewer augers I started reading about water jetting lines. I have a gas pressure washer and found this website http://www.ultimatewasher.com/sewer-jetter-hoses.htm that sells parts to convert your pressure washer into a water jetter. Seems it would only cost about 200 bucks to get a 100 ft hose and a couple of nozzles.
Has anyone done this? If so how did it work? Thanks
ponch37300 is offline   Reply With Quote
Old 07-06-2009, 07:18 PM   #2
http://www.terrylove.com/forums/showthread.php?t=29795
Be sure to watch the chicken video.
Watch your fingers!
http://www.bt.cdc.gov/disasters/pres...sherinjury.asp
Gamble $200 on something used infrequently and that may not work or $100 for a pretty much sure thing.
If the conversion may work to 50% or better likelihood it is 'rational' to spend the $200.
I just use a garden hose from my water heater drain faucet to clear most clogs but you might need more pressure/GPM than this method.
Old 07-06-2009, 09:07 PM   #3
Rewards Points: 16
I'm not sure how well it works, I'll have to check my pressure and GPM and see how it compares to the others mentioned. From the videos it looks like it works pretty good. I'm not a fan off paying 1/5th of something to use it for one day. If I decide to go the auger way I will probably just spend the money and buy one. Thanks for the links.
Old 07-06-2009, 09:26 PM   #4
HVAC / Plumbing
If it's stopped up with roots , etc, .The jetting won't help. You will need an auger. If the old pipe has collapsed . You need a new sewer line
kenmac is offline   Reply With Quote
Pressure washer advice mntentman Tools 1 09-03-2008 09:36 PM
excell pressure washer help ericsloan Tools 1 06-14-2008 03:39 PM
Pressure Washer Question DIYchick Tools 8 02-05-2008 06:44 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
